rob2218
JAVA issues again with TW and messaging communication?
again....is this thing a JAVA issue?
last time we updated and installed the latest JAVA 7 update 21 on our server. seemed to have fixed this very same issue.....for only the time being...seems the 'issue' is back.
we can't communicate with our TW co-workers...but we can do a send/recieve. What the hell is going on here guys???? really.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
1 Reply 1
rob2218
we spoke to GS ARchiplus tech support, we spoke to our I.T. guys...here are the findings:
1. we had two versions of java (JAVA 6/upgrade 35 and JAVA 7/upgrade 21).
2. they "appear" to be conflicting with each other according to G.S.
3. we needed to remove JAVA 6
4. also, remove the TW Messaging file from the server (BIM Server): folder/files are located at:
a. C:/Drive (server drive)/Program Files/Graphisoft/BIMServer/ServerModule/1600/TW Messaging/DATA (the DATA folder could be removed).
that should do it.
then once JAVA7 is the "THE ONLY JAVA VERSION ON THE SERVER" (where the BIM Server software resides)...this should clear up the problem.
Hope this helps someone for future occurances....keeping fingers crossed that this is cure.
I wonder sometimes on all this 'voo-doo BIM'.
i>u
Edgewater, FL!
SOFTWARE VERSION:
