When I'm working with 1 project only everything is just fine. The Problem with the "UNDO" not being able is when I'm working with more the 1 project at the same time. Then the second project doesn't allow me to "UNDO"
And it Crashes when I attempt to drag multiple copies of an object.
Does anybody have a clue to find a solution?
Thank you in advance.
ArchiCAD 26 MacOS Monterey MacBook Pro Apple M1 Max 64 GB
We are getting it but it seems to be triggered by some unknown factor. Just having two TW files open doesn't automatically do it. Seems like it is triggered by something and the only way to get it back is to close down the instance having the problem and relaunch ArchiCAD and all seems to be fine again.... until the mystery trigger happens again.
