Teamwork & BIMcloud
NO UNDO WHILE MORE THAN 1 PROJECT OPEN ON TW AC13
archigreen
When I'm working with 1 project only everything is just fine. The Problem with the "UNDO" not being able is when I'm working with more the 1 project at the same time. Then the second project doesn't allow me to "UNDO"
And it Crashes when I attempt to drag multiple copies of an object.
Does anybody have a clue to find a solution?
Thank you in advance.
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
10 REPLIES 10
I also have this problem.
Undo doesn't work on the second project when I have 2 teamwork projects running at the same time.
We've seen this problem as well... hoping that graphisoft wakes and fixes this issue...
archigreen
I thought I was all alone in this world!
So, there is life in other planets then.
Lets hope AC14 will fix this problem
Cheers!
ArchiCAD 26
MacOS Monterey
64 GB
Link
Fortunately it works fine here on AC13 AUS 3547 64bit Full.
Link.
kevin b
We are getting it but it seems to be triggered by some unknown factor. Just having two TW files open doesn't automatically do it. Seems like it is triggered by something and the only way to get it back is to close down the instance having the problem and relaunch ArchiCAD and all seems to be fine again.... until the mystery trigger happens again.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
We are on Macs and have this same issue too. I wonder if this is
Mac only issue - would help if signatures here had more info
Regards, Juha
Achille Pavlidis
Same here...
two projects open (one TW file, and one PLN file) and no undo on the TW file...
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
schagemann
and here another one with the same problem...
on a mac the undo command is not working when working on multiple AC13 AUS TW files simultaneously.
ds.
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
We have had some success with deleting the TW Data folder to reset the local Teamwork Cache files and it seems to be working.
