Teamwork & BIMcloud
Tips about Teamwork, plus BIMcloud functions and settings
Not found any BIMcloud related license
I've installed BIMcloud-2019.3 and it fails for me during the BIMcloud Manager. It says:
BIMcloud Manager configuration failed
Please check the log files for details.
The last log file written to in the log directory is the license_manager file and it says:
[2019-09-04 00:25:10] WARN [license_manager] - Not found any BIMcloud related license
I'm trying to use BIMcloud Free, in any case.
2 REPLIES 2
Noemi Balogh
Hi famadorian,
The error message you mentioned is a logging issue in BIMcloud - it should be not there, but some kind of actions can trigger it.
However, I suspect the configuration failed because the BIMcloud Manager could not restart in time (approx. half a minute).
It happens either because:
- the hardware is not strong enough under BIMcloud and every process is pretty slow,
- a 3rd party application blocks the communication and run of BIMcloud (e.g. antivirus is running on the computer) - try to turn it off if this is true,
- maybe there are not enough ports available - in this case a computer restart should help,
- or one of the Manager's ports are reserved already (usually by another BIMcloud),
- or something strange happened during the installation, and it causes all the trouble.
If you still can't find the reason, send me a private message and we can talk about further details for an investigation.
Kind regards,
Noemi
Noémi Balogh
Senior Community Expert, Admin
Ok, I installed onto another station and it still failed
I then installed it onto another server again, and it still failed.
Then I found another more powerful station and it worked.
You don't think you could be a little more verbose, than giving this nonsense error message?
