Problem with Teamwork views linked to PLN file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-02-23 04:01 PM
Today when i wanted to update the views of the Teamwork file, i get this error message: "Unsent changes in your source project are preventing the status checking process.
Go to the project and send your changes to the Server, then press the Check Status command again in the current project."
I did Send and Receive a lot of times, but to no avail, i cannot update my views. Even if i delete them and re-link them i get a blank drawing.
What can i do???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-06-30 03:42 PM
When i open the PLN files and save them to the same build as the file containing the layouts the problem is solved. No error messages.
I don't remember if this happened with the previous builds...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-07-22 05:54 PM
They were supposed to have found the problem... (thats what they said on the bug fixes for build 3600) but nothing...
We have an deadline tomorrow and we are struggling to update lined views!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-28 08:49 AM
One thing I noticed: When opening the solo file with the linked views and linking from the TW file, AC automatically Joins to the TW project the user from who's the computer the solo file is opened.
If I open the BIM server window i see that the other user has joined the project. But when i open my TW local copy the other user that joined is not on the list (not even as offline)
Does all this make sense?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-28 06:19 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-29 04:37 PM
I was just asking if it is normal for a user that has not joined the project, to get automatically (and without any warning) joined to the project, only because he is linking views to the solo PLN file from the TW file.
And after being joined (and thus appearing to the BIM server project settings) to not appear to the teamwork palette to other users working on the project...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-12-08 01:52 PM
did you ever get an answer on this one from GS?
I'm getting the same Error message while loading from another TW files viewmaps into mine.
Thing is.....only a few of my users get it while others (myself included) don't.
Same exact error message.
AC tries to open the viewmap coming in from another TW file, it hangs, then error message comes up and doesn't update the sheet.
What's the fix Graphisoft?
What gives here?
Please help.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-12-08 02:02 PM
But, what i have discovered is that instead of using send/receive if I use just "send" the views are updated. For some reason the "send/receive" command messes up the whole thing, and the file with the drawings "thinks" that there are unsent changes...
My advice in general when using TW: Stop using the "Send/Receive" command. Use first "send" then "receive". Saves a lot of trouble.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-19 05:13 PM
This time i get this:
I link drawings to the pln file, but when i reopen the pln, all links are broken, and i cannot update the views. I have to re-link them each and every single time... If i open the Drawing Manager i get this new error message "Server Offline" but my server is NOT offline at all!
What to do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-01-25 12:03 PM
but... i have a question... why when i open the file with the linked views on another computer i get on the path a parenthesis with the name of the user which i don't see when opening the file on my computer... see attached images... why is that?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-01-12 10:07 AM
I get the same error message "Unsent changes in your source project are preventing the status checking process"
No matter how many times I send changes, me and all other members there there seems to be unsent changes.
Also I noticed that in the teamwork open dialog box, 3 projects including the one that is giving me the problem, appear with unsent changes...
Any solutions?
