Teamwork & BIMcloud
TEAMWORK BETWEEN 32 and 64 bits
can i connect 2 computers to work with archicad teamwork if one is 32 bits and the other is 64 bits?
they are both fully updated
5 REPLIES 5
Rob
they will work.
The only limitation is the project size, apparently as soon as the project gets bigger than 32bit addressable space (4GB) you will not be able to open it on 32bit system.
::rk
and whats the adressable space? and how do i know when it is about to reach 4gb?
You can open the Task Manager (CTRL+ALT+DEL) and there you will see how much memory ArchiCAD is using. I don't think you need to start worrying if it is well below 2 GB (2,000,000 KB).
ohh ok thanks.. one more thing.. then whats this number for? ..watch attachmnet"
It displays the available free RAM you have that no application is currently using, the higher the number the better cause it means your computer has more resources available.
