Teamwork & BIMcloud
TW2 Education + Univ licenses
Eduardo Rolon
Will TW2 and BIM Server be available for EDU and University users?
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
17 REPLIES 17
Hmmm so from what I am gathering is that I cannot open my Archicad 12 educational files in Archicad 13. Archicad 13 educational is not available yet - so I'm stuck in 12 educational? I apologize if I am missing the obvious....
Eduardo Rolon
Yes you can! See my previous post.
Does this has anything to do with TeamWork2?
AC27 US/INT -> AC08
another Moderator
I am not using Team Work at all. I have tried several different ways to open my educational file in Archicad 13, and it is not working. That is where I am stuck
Eduardo Rolon
You should open a new thread, but to be clear YOU CAN OPEN EDUCATIONAL AC12 FILES in AC13 Commercial. You CAN NOT copy/paste between an EDU and a Commercial Version which apparently is what you are trying to do.
Based on what you wrote, close the AC12 file running in AC12 Educational open AC13 and open the file, AC will give you the warning that it is switching to Educational and that's it.
AC27 US/INT -> AC08
another Moderator
Oh I got it! Thanks for your help!
Hi there, I can't open my ArchiCAD 12 EDU files in my ArchiCAD 13.
I'm running ArchiCAD in Mac.
EDU files cannot be used in the FULL version.
This has always been the case.
Eduardo Rolon
To repeat again.
You cannot CONVERT from EDU to Commercial, nor copy/paste between them, link files or modules.
You can OPEN EDU in Commercial but it will switch the Commercial to EDU as long as the file is open. For this to work you need your USB Dongle even though the EDU is controlled by a serial number.
AC27 US/INT -> AC08
another Moderator
