Teamwork file on two computers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-05-28 01:56 AM
This happens regularly to multiple users but definitely all changes have been sent prior to closing the file from the previous computer. Is this a bug?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-28 04:01 AM
However, it seems like a similar message as when you try to open a non-teamwork file that is already open.
I know the whole reason for teamwork is that multiple users can open the same file at the same time.
But is it a case that you have not closed the file on your home machine - i.e. it still assumes it is being edited by you.
You then try to log in at work as the same user which is causing the problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-28 04:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-28 09:07 AM - last edited 2 weeks ago
Hello Benjamin,
This is a generic warning in ARCHICAD Teamwork, with the simple reason that it is not really recommended to regularly switch between computers with the same user - project combo.
Data integrity is the most crucial thing while you work in Teamwork. ARCHICAD checks regularly if there are any unsent changes - compares your local data with the database the BIMcloud Server has. What it cannot do is to remember and tell for sure, if you really sent everything to the Server. So when you switch between computers, the current ARCHICAD has no clue what you did on the other computer. There is no such database which would know "yeah, this user was careful enough, they sent up everything, released what was necessary, nothing else to do here". It is not something predictable.
However, you can go this way, and work from different computers, and if you are careful, you most probably won't have issues, but you cannot skip this message.
Kind regards,
Noémi Balogh
Community Expert, Admin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-28 09:37 AM
The reason why this situation is happening is because of part time working from home (E.g. they work from home a few days, then come to the office a few days). They have a desktop tower at home and hot desks at work (not feasible to move the tower back and forth)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-28 10:39 AM
One for 'user_home' and another for 'user_work'.
That way teamwork will think there are two different users working on the file.
So long as changes are sent and received and all is released when changing locations it should work?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-29 08:24 PM
Not as flexible as creating two users as suggested by Barry, though.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-05-30 06:32 PM
About Travel Pack - I don't recommend to use it, the content will go offline, it was created for a different purpose back in time.
For such case, there's no better option than being careful and accepting the warning message will appear every time you switch between computers.
Noémi Balogh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-06-21 02:32 AM
Does anyone know if this issue will be looked at in the upcoming 26 release ?
There must be more AC users that switch between computers that use teamwork. It's kind of important when planning office equipment purchases.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-06-21 03:14 AM - edited 2022-06-21 04:39 PM
That is no issue at all. It is just letting you know that your user will start accessing and modifying that tw file from this other computer, so any unsent changes (which the server has no way of knowing about) by this user (which strictly speaking may have been you or someone else) on the previous computer will be lost. Everything is fine, and actually it is a very nice, thoughtful warning.
