Teamwork & BIMcloud
Unable to update BimServer 18 to 5100
Eduardo Rolon
I keep getting the following error:
"BIM Cloud detected the same version of BIM Server already installed on this computer. BIMcloud cannot be installed".
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
12 REPLIES 12
Eduardo Rolon
When I try to either Share or Connect to BimServer I get the following:
"Your client is not compatible with the BIMcloud Manager
BIM cloud version : 18.0.0.3006
Client Version: 18.0.0.5100"
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Suggestions?
AC27 US/INT -> AC08
another Moderator
Are we talking about the BIM Server or the separate BIM Server Manager application?
Eduardo Rolon
BIM Server.
I can log with the manager after installing 5100 and it indicates that the 18 Module is running 3008?.
AC27 US/INT -> AC08
another Moderator
Sorry, then I don't have any good suggestions besides a possible reinstall, then update again. Maybe cleaning preferences as well?:
http://helpcenter.graphisoft.com/troubleshooting/setup/preferences-cleaning/
NCornia
Eduardo,
BIM Server ≠ BIMcloud
It appears that you are trying to run the BIMcloud update on your BIM Server. Use the ArchiCAD-18-Update-5100 update on both ArchiCAD workstations and on the BIM Server. Same update since BIM Server is a free component of owning an ArchiCAD license.
However, I see the dilemma since the error in ArchiCAD refers to the BIM Server as BIMcloud Manager. I will bring this to the attention of the product team.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Eduardo Rolon
Nick,
We tried both the regular and the BIMcloud one. None worked.
AC27 US/INT -> AC08
another Moderator
I have similar problem where I can not install BIM Server because is says I need to remove an older program first. I tired and can see not trace of it but it must still be running some file I can't get to.
How can I delete all files of a BIM Server/BIM Server Manager/ BIM Cloud...?
Hi!
I have the same problem here.
I want to use BIM server (free one) and when try to share project it alerts me that bim server is older version 3006 instead of 5100 as archicad.
I have tried clean install of ArchiCAD.
