Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Teamwork & BIMcloud
"Share" button is grayed out - Connections are OK
Ruben V
I can connect to the remote BIMserver (over VPN), but when I try to share a project, the "share"-button is grayed out.
I opened the necessary ports on my mac & router (18008 & 1228), but nothing helps (not even turning off firewall temporarily).
Any Ideas on what might be wrong?
PS: working within the servers network (no VPN) doesn't change this...
As you can see on the screenshot, making and managing folders is possible...
(òÓ,)_\,,/
www.studiov2.be
Archicad 26/27 + Rhino/Grasshopper
BIMcollab ZOOM
>>> Read my book!<<<
28 REPLIES 28
Ruben V
Maybe this screenshot may help you... to help me? Please?
(òÓ,)_\,,/
www.studiov2.be
BIMcollab ZOOM
>>> Read my book!<<<
Hi B.E.A.T.
I had the same issue and have been pulling hairs all day..
I have fixed it my end.. :]
Basically I was getting an error message when I uninstall the BIM Cloud Module. I installed / uninstalled plenty of times.
For some reason when I tried to reinstall BIM Server I would get an error message re BIM Cloud. Same for uninstall.
I think that dropped some files deep in the system that messed things up.
I did this.
Delete any
/ library /preference/com.graphisoft.BIMcloud.plist ish files
/ library / LaunchDaemon / *graphisoft* files
/ users / shared / graphisoft files
Then run 'uninstall BIM server'
Then run disk utility (assuming Mac) and repair permissions.
Then restart.
Then reinstall BIM server.
Hope this helps.
Andy
Marton Kiss
All,
we collected all known issues and solution in this article: http://helpcenter.graphisoft.com/?p=40585
I hope it helps,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
I am having the exact same problem. I have tried two different Windows Server installations on different instances in the Amazon EC2 cloud without success. Everything else is working and the Manager is available over the web. Connections are good according to attached image.
Problem 1
I can't share a project because the shared button is greyed out as above.
Problem 2
I can´t upload a library and I am experiencing the same result as B.E.A.T showed in his image above.
Unfortunately I cannot find any solution to these problems in the quoted articles http://helpcenter.graphisoft.com/?p=40585
It is really important for me to solve this problem. Any suggestions?[/img]
Marton Kiss
It might be really basic, but please double-check that the BIM Server has been already activated.
Connect to it via a browser, modules, BIM Server Manager, Licenses.
Marton
Marton Kiss
GRAPHISOFT
Licenses are ok
Summary:
- Licenses are ok
- Connections are ok (See image)
- But there is no Host Server (See image)
I still can't use share project or upload Library
Marton Kiss
On the modules tab do you have the v18 module listed next to the BIM Server Manager?
Marton Kiss
GRAPHISOFT
No, I only have the BIM server Manger under Modules
