dabelow
3D Graphics got worse 24>27?
We just switched from AC24 to AC27. The 3D graphics got much choppier/jagged going from the OpenGL engine to the Accelerated Hardware engine. We played with our 3D window size/pixels but had no change. Some example images are attached. This is an office-wide problem. How can we make our model smooth again?
Processors vary (mine specifically is Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz); all support OpenGL 4.5. Graphics cards are NVIDIA Quadro RTX 3000 with Max-Q Design, build 532.09. System refresh rate is 60Hz. Windows 10 Pro v22H2. 64-Bit. This particular laptop is a Dell Precision 5750, although not everyone has this model.
4 Replies 4
In Archicad 27, is 3D Antialiasing turned ON in the Advanced Redraw Options page of the Work Environment Dialog?
dabelow
We've tried it both checked and unchecked, with no discernable difference in the view quality.
Someone else has noticed a similar problem and said a restart seems to have fixed it (I have no idea why that would work).
https://community.graphisoft.com/t5/Visualization/3d-Antialiasing-in-Archicad-27/m-p/576897/highligh...
So make sure antialiasing is on for 3D and restart Archicad.
I would probably restart the machine if you haven't done that in a while.
hevi
Ace
Make sure that the 3D window is closed and opened as it is needed for the change to have effect.
