2023-11-17 10:09 PM
We just switched from AC24 to AC27. The 3D graphics got much choppier/jagged going from the OpenGL engine to the Accelerated Hardware engine. We played with our 3D window size/pixels but had no change. Some example images are attached. This is an office-wide problem. How can we make our model smooth again?
Processors vary (mine specifically is Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz); all support OpenGL 4.5. Graphics cards are NVIDIA Quadro RTX 3000 with Max-Q Design, build 532.09. System refresh rate is 60Hz. Windows 10 Pro v22H2. 64-Bit. This particular laptop is a Dell Precision 5750, although not everyone has this model.
2023-11-18 02:18 AM
In Archicad 27, is 3D Antialiasing turned ON in the Advanced Redraw Options page of the Work Environment Dialog?
2023-11-20 04:10 PM
We've tried it both checked and unchecked, with no discernable difference in the view quality.
2023-11-23 02:49 AM
Someone else has noticed a similar problem and said a restart seems to have fixed it (I have no idea why that would work).
So make sure antialiasing is on for 3D and restart Archicad.
I would probably restart the machine if you haven't done that in a while.
2023-11-23 08:35 AM - edited 2023-11-23 08:36 AM
Make sure that the 3D window is closed and opened as it is needed for the change to have effect.
