Visualization
3D Text with Luminance
We have a need to take a piece of 3D Text made in Archicad and get either the rear of the text to have Luminance or create the same affect in other ways such as very thin duplicate text behind the main text that hold the luminance. The key seems to be either converting the text to a Morph or adding a New Surface to existing text.
Any suggestions are appreciated.
Thanks
I'm confused... seems you answered your own question... convert the 3D test object to a Morph and change the material of the back surface to one with luminance. Which part do you need help with?
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
We actually solved it by creating the separate text element with luminance and just pasted to the rear of the forward facing text
Eduardo Rolon
I thought that was my suggestion…
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
