‎2015-11-23
04:57 PM
‎2023-05-11
01:25 PM
Noemi Balogh
‎2016-08-24 05:40 PM
‎2016-08-24 05:41 PM
‎2016-11-23 06:14 PM
‎2016-11-23 09:33 PM
‎2016-11-25 10:33 AM
JustinX wrote:
This is Seriously not acceptable!!!
AC20 is nice and all...but what about updating between AC and C4D!!!!(':evil:')
There's always been a good workflow between AC and C4D. Even without the Din3D plugin. Just by simply using the C4D exchange plugin you could update models in C4d after adding Materials, Objects, Lighting and what not.
The current C4D plugin doesn't even export properly. Its scaling is completely off and won't update!! And now I READ this ':shock:'.
Really Graphisoft...why not just simply update the C4D exchange plugin properly for AC20??? (don't tell me that AC is coded deferent wich makes this hard
The PhotoRendering Setting pallet export is good...but again...where are the update functions!!!??? Not really a useful workflow if you can't update the geometry like in Lumion or Artlantis.
Question for Graphisoft: Are you looking in to this or even considering a proper workflow option between AC and C4D?:?::?::!::!::!::!::!:
‎2016-11-25 03:45 PM
‎2016-11-25 08:18 PM
‎2016-11-26 11:48 AM
JustinX wrote:Hi Justinx, I was talking about an old application named "Maxonform", that allowed fully exchanges between ArchiCAD and Cinema 4D.
hallo ciciolo.
Could you direct me to that forum?
Maybe the guys at Maxon don't know that their plugin isn't working with AC 20.
Because on Graohisofts site you can clearly download the C4D exchange plugin plugin for AC"20". Only...it does not work!!!!!
and to be clear this is a AC 20 problem. because I have tried various things.
And the export/update problem is only when exporting from AC "20". AC 19 does the job.
‎2017-01-20 03:46 PM
