ArchiCad 18 Cinerender Lights On / Off
I have spent a great amount of time simply trying to make lights work, within ArchiCad 18. I have placed a light and made sure that it is on. I have toggled many settings on / off to see what would work. I have not had any luck with seeing illumination. If anyone could find time to help me, I would greatly appreciate this. - Jakub
4 Replies 4
Erwin Edel
There is a slider on cinerender window that controls the strength of sun, lamps and light emitting surfaces. Is the lamp slider on 100%?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thank you, Erwin. I took another look at this Cinerender Setting and you are correct. I had 'Lamp' Setting selected but this is set to 0 by default. Your quick response is much appreciated! - Jakub
Erwin Edel
Right, but I also mean the slider mentioned in Light Sources here http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/visualization/photorendering...
www.leloup.nl
Attached is an image of that Setting change, for anyone's future reference. Thanks again, Erwin.
