Visualization
Art. vs. C4D
Red
I'm looking to buy a rendering program and I'm just wanting some input on which one is the best.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
8 REPLIES 8
Ben Odonnell
Lightwave
Ben O'Donnell
Stefan Boeykens' web site has a variety of interesting information to help you see what some of the different products can do and how hard it is to do it:
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/
AC 29 USA and earlier   •   hardware key   •   macOS Sequoia 15.7.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Djordje
The one you know how to do what you clients want with.
I would follow Karl's advice - go to Stefan's site. Analysis, pro et con, all is there.
Another issue to consider: interoperability, workflow, compatibility.
Let us know
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Red
For the most part the customers I will be dealing with want me to come out and take several pictures of the view they have and use it as the background. I will mainly be doing exterior rendering so they can have a nice little framed picture to hang on their wall. Also very few if any interior renderings (walkthroughs) etc have been requested. But I would still like to be able to do good quality walkthroughs if requested.
So when shopping for a rendering program if one is better at exterior than interior renderings (walkthroughs) that would be mainly what I’m looking for.
Thanks,
Red
i7 8700k
64gb RAM
AC6 to Current
Best way to get a feel is to run demo programs for at least 2-3 hours. Try this>
I have put together a little file,
http://www.Burginger.com/ARCHICAD_TALK/C4DZIP.ZIP
This is a 3 MB file containing a Cinema4D file that originated in ArchiCAD. For those interested in Cinema4D, download the Cinema4D demo program from:
http://www.maxoncomputer.com/
Then download this file that I put together and you will be able to play with it. If you have any questions I will be happy to answer them.
This is a really easy to use program, especially if a file is preset for you to browse. This was a quick and dirty, I really don't have the time to perfect the file, but it will give good results.
James B
So what's so good about Lightwave?
Nice renders, but I hear it's difficult to use/pick up.
James.
James Badcock
I think it's pretty important to consider your current knowledge on rendering before deciding on packages. I appreciated Artlantis initially as I had no (other than AC) render experience prior to picking it up. It is fairly user friendly, easy to learn & it's quite possible to achieve results fairly quicky. I then moved on to C4D once I'd grown out of Artlantis, but the step was huge, learning a new language almost. So for me, it comes down to the time you have available to learn the new package, & the results you expect from it. If you're expecting to get photo-real images straight after cracking the box open out of, say, C4D or Lightwave, forget it. They present the possibility of a better end result, at an extra cost in initial $$ & learning time = down time from making actual money.
Justin
'Not trying to put anybody off, just pointing out what I found hard in the experience...'
stefan
If you want to invest time (and courses), then Lightwave, Cinema4D, 3ds max/VIZ, Maya and others can do everything you want. They are expensive.
If you have less money, but still need a flexible 3D-animation program, you can try Carrara, Realsoft3D, Strata3D, Truespace, Pixels3D.
If you have no money, but want to have a full animation tool nonetheless, then the new Blender is looking good. There are others, like 3D Canvas.
If you have no money, but want a better rendering engine (and have some time to invest and learn some coding), then BMRT, Virtualight, POV-Ray, Radiance & similar programs can do a good job. But I find this the hardest way.
So take a look at:
The Render Study:
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/render/render.htm
The Shootout:
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/shootout/shootout.htm
ArchiCAD -> Cinema4D
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/tips/ac2c4d.htm
And see if this is what you want to do.
On the other hand, if you don't want to learn much and just want a very straightforward rendering companion for ArchiCAD, then AV-Works or Art*lantis are hard to beat. And then there is this thing ArchiLumos, but only in Japan and Sweden, apparantly.
It's all down to the time & the money you'd like to invest in it.
Archicad-user since 1998
my Archicad Book
