‎2018-01-19
11:14 AM
‎2023-05-11
11:55 AM
Noemi Balogh
‎2018-01-19 11:16 AM
‎2018-01-19 11:44 AM
‎2018-01-19 12:52 PM
‎2018-01-19 01:59 PM
Erwin wrote:Well, this doesn't work either, Erwin?
As a workaround, you can tick the 'generate alpha mask' and add the background picture in photo editor.
‎2018-01-19 03:17 PM
‎2018-01-19 03:19 PM
‎2018-01-19 03:32 PM
Erwin wrote:Halleluja! Thank you so much, Erwin.
Make sure you set 'High Accuracy Color with Alpha Channel' under options when saving. Not sure if TIFF supports transparancy alpha channel. PNG does for sure.
‎2018-01-19 03:40 PM
Erwin wrote:Interestingly, this works as well.
Also, just copy and paste to your image editor should work, but maybe not for Alpha Channel. I never save out my renders, I just copy and paste directly to Photoshop, as I always do some manipulation there.
