JP
concepsys
Cineware by maxon add-on has unexpectedly closed. - Windows, all Archicad versions - Solution
When opening rendering settings or starting render directly, Archicad would wait for about 5 minutes and then opened a message saying "Cineware by maxon add-on has unexpectedly closed". Even in a new empty file.
This was happening both in Archicad 26 & 29, the version I have installed at the moment.
After spending a few hours searching online for occurrences of this problem and possible solutions, none of them seemed to work.
  • I switched the NVIDIA drivers from Game Ready to Studio,
  • installed the C++ Redistributable x64 and x32,
  • assigned Archicad and Cinerender directly to the RTX GPU to prevent them from using the onboard Intel.
I tried everything I found, and nothing worked.
Eventually, I went into Archicad’s Cineware folder and ran the cinerender.exe executable. A message appeared saying that the file libmmd.dll was missing. However, that file actually exists a few folders deeper… in /resource/libs/x64.
I copied that file from /resource/libs/x64 into the Cineware folder — basically placing the DLL right next to Cinerender.exe — and it started working. I had to do this for both version 26 and version 29, but it immediately worked in both cases.
It must be a rare issue because it only happened on my laptop. A system path issue, probably.
On my desktop PC, for example, it doesn’t occur. Still, here's the solution that quickly worked for me.
I hope it helps someone else.
1 Reply 1
Andreas81ch
I had the same issue.
Told this to our Swiss partner IDC, they sent me a new Cineware folder with files (to change the old Cineware folder with the new one).
Then it worked again.
ArchiCAD v6.5 - 29 (CHE Swiss Edition / Schweiz) - macOS / WIN - Workstation in office: mac OS 26.5.1, Apple M2 Max, 64 GB RAM
