2024-06-10 11:01 PM
I have Archicad 27 Build 5030 and when i render something sometimes i have this error: Cineware by maxon add-on has unexpectedly closed.
Even with Build 3001 i had the same problem.
It's very frustrating, could someone help me please?
Operating system used: Mac Apple Silicon Sonoma 14.5
2 weeks ago
Try clicking on "Done".
Replacing the folder should work.
2 weeks ago
I clicked on "Done" but I get the same message the next time that I start ArchiCAD.
2 weeks ago - last edited a week ago by Laszlo Nagy
Redshift is another rendering plugin of Archicad and if am not mistaken it should be subscription base.
2 weeks ago
I have seen no mention of it being subscription only.
But it is certainly hardware dependent.
2 weeks ago
@Barry Kelly not sure if this link helps.
https://help.graphisoft.com/SOLO/27/INT/_AC27_Help/143_Redshift/143_Redshift-1.htm
2 weeks ago
That says you need an SSA/Forward support agreement, which is different from collaboration subscription, which is what I thought you meant.
So, for Redshift you need to have a current support package as well as the hardware to run it.
