2024-06-10 11:01 PM
I have Archicad 27 Build 5030 and when i render something sometimes i have this error: Cineware by maxon add-on has unexpectedly closed.
Even with Build 3001 i had the same problem.
It's very frustrating, could someone help me please?
Operating system used: Mac Apple Silicon Sonoma 14.5
2024-11-06 01:06 PM
Try clicking on "Done".
Replacing the folder should work.
2024-11-07 07:27 PM
I clicked on "Done" but I get the same message the next time that I start ArchiCAD.
2024-11-08 04:20 AM - last edited on 2024-11-13 10:59 PM by Laszlo Nagy
Redshift is another rendering plugin of Archicad and if am not mistaken it should be subscription base.
2024-11-08 04:31 AM
I have seen no mention of it being subscription only.
But it is certainly hardware dependent.
2024-11-08 05:56 AM
@Barry Kelly not sure if this link helps.
https://help.graphisoft.com/SOLO/27/INT/_AC27_Help/143_Redshift/143_Redshift-1.htm
2024-11-08 06:09 AM
That says you need an SSA/Forward support agreement, which is different from collaboration subscription, which is what I thought you meant.
So, for Redshift you need to have a current support package as well as the hardware to run it.
