Visualization
Cineware by maxon add-on has unexpectedly closed.
Arch Introini
I have Archicad 27 Build 5030 and when i render something sometimes i have this error: Cineware by maxon add-on has unexpectedly closed.
Even with Build 3001 i had the same problem.
It's very frustrating, could someone help me please?
Operating system used: Mac Apple Silicon Sonoma 14.5
15 REPLIES 15
Try clicking on "Done".
Replacing the folder should work.
From Archicad 17
MacBook Pro M1 Max
I clicked on "Done" but I get the same message the next time that I start ArchiCAD.
Steve Pribyl
MAC OS Sonoma 14.5
ArchiCAD 28
Redshift is another rendering plugin of Archicad and if am not mistaken it should be subscription base.
In the end what is your Objective?
ArchiCAD 9 onwards
I have seen no mention of it being subscription only.
But it is certainly hardware dependent.
@Barry Kelly not sure if this link helps.
https://help.graphisoft.com/SOLO/27/INT/_AC27_Help/143_Redshift/143_Redshift-1.htm
ArchiCAD 9 onwards
That says you need an SSA/Forward support agreement, which is different from collaboration subscription, which is what I thought you meant.
So, for Redshift you need to have a current support package as well as the hardware to run it.
Setup info provided by author
