‎2018-10-09
07:28 AM
‎2023-05-11
12:48 PM
Noemi Balogh
‎2018-10-09 07:43 AM
‎2018-10-09 07:55 AM
Lingwisyer wrote:I have done that, you can see the windows at the top are transparent. The surface of the glass in the sliding door is the issue. It is glass but it doesnt show as glass, the frames are white too when they are just meant to be wood too.
You will need to enable transparency in your render settings.
Ling.
‎2018-10-09 08:14 AM
‎2018-10-09 08:20 AM
Lingwisyer wrote:Thats what I thought too, There is no Graphic Overrides on currently and I cant see anything that would do this to the sliding doors. Also it seems weird that its only this specific door when other hinged doors work fine.
Since they are not even showing as transparent in the 3d window, might this be due to aMVObeing designated to the door? Not sure if they affect renders... Or possibly a Graphic Override?
Ling.
‎2018-10-09 08:30 AM
‎2018-10-09 08:39 AM
Barry wrote:Ive had a look and cant find anything that might be doing it. I dont understand why it would only be changing this one surface on one type of door when other doors/windows with the same surface on the same renovation filter work fine.
You mentioned Renovation Filters before.
They can override surface materials as well.
Check the override settings of your reno filters.
‎2018-10-09 09:27 AM
‎2019-04-19 02:19 PM
‎2019-04-26 10:02 AM
