I'm not sure if Cinerender is an option for you, but I just did a quick render with fairly low settings, to match OpenGL in terms of what that would show.
A 300 dpi 195x135 mm image rendered in 1:30 min.
This is with a procedural skybox and the project I tested has quite a few textures.
I dropped one 'infinite' general light inside to light things a bit.
If you start out with Outdoor Daylight Fast (Physical), tweak detailed settings as follows:
- pick a nicer sky (remember to tick Use ARCHICAD Sun Position)
- Light Adjustments: sunlight 100, lamps 50 (or higher if you want more light inside)
- Environment > Physical Sky > Clouds > turn off cast shadows
- Options > General Options > only use Transparancy and Textures, Ray Treshold 0, Ray Depth 12, Reflection Depth 12. The 12 is for 6 layers of glass / transparant items, adjust as needed. 12 is a safe number for me, the impact on render times is there, but 1:30 min, what is the point?
Cinerender will happily render out these frames while you keep working, the render times may increase a bit when doing more than one render, but still it should not take that long and your images will be excactly the size you want them to be.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
