2004-12-02
12:29 AM
2023-05-11
01:12 PM
Noemi Balogh
2004-12-02 03:55 AM
2004-12-02 05:45 AM
David wrote:
I am testing some of animations with artlantis, already I did a movie but now I have some doubts
1. The file of .mov was 1.62GB in format (quicktime
compressed) size 768 576 xs the PAL 25 photograms by seg. with
duration of 40 seconds.
2. Then I tested another in format (quicktime compressed) size
320 200 xs VGA 25 photograms by seg. with duration of 30 seconds. the
file .mov was 182 MB
David wrote:
Then I change some textures that you could be larger in size
and saving them with smaller KB
David wrote:
Is normal the size of the file for .mov?
The other doubt that I have is if a file .mov I can save it in a DVD,
and send it to my client and he can see it in any DVD?
the program iDVD has this option?
does anybody knows how to make it?
2004-12-02 09:38 AM
2004-12-02 09:15 PM
2004-12-03 02:28 AM
ricki_faris wrote:Maybe I have misunderstood how animation compression works, but I thought the answer to this would be 'yes' - if the textures change, but not if the texture files are merely compressed better. I thought that with animation compression, areas of consecutive frames are examined and if an area has not changed from one frame to the next, it is encoded so as to not be stored in the subsequent frame(s).
If you mean the textures that you are using in Artlantis for your materials, then this will not affect your rendered images/movie file size.
2004-12-03 04:09 AM
If this is the case, then if a wall is white in one case, and has striped wallpaper in another, then the white wall animation should compress better (depending on lighting effects) as you walk past it ... while the areas of the striped wall can have much less compressionl because of the 'moving' stripes.
2004-12-10 01:49 AM
2004-12-10 02:29 PM
Burginger wrote:The last sentence is a bit biased... Whatever you told is perfectly possible on a PC as well.
The Mac Rocks!
2004-12-10 03:27 PM
The last sentence is a bit biased... Whatever you told is perfectly possible on a PC as well....But the programs (iMovie,iDVD,Garageband) come free with any mac and if you need to buy them they are only $49.00US
another Moderator
