Visualization
Illuminated Sign
Has anyone been able to create a typical business box sign that would be illuminated at night.
32 REPLIES 32
Eduardo Rolon
Here's the trick with 2 different JPGs, one for color and one for illumination
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Don't forget to use " Match internal to C4D" and to turn Illuminating Surfaces on and in this case it is set to 200
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
With the same JPG on both color and Luminance
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
and painting the white area yellow
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
For the JPG make sure it has the same proportion as the Morph.
In this case the Morph is 16'-0" by 4'-0" so the JPGs are 8" by 2" at 72 DPI this will ensure that you don't slow down the file by having huge images in the Library.
Karl, render time should be a fraction of using Volumetric lights in this samb=ple it was rendering in 8 secs a 600x800 image.
AC29 US/INT -> AC08
another Moderator
Not sure I am even in the right place in terms of windows for this. I have .jpgs stored in a folder called Logos but that does not appear in the Library window. I have no issues getting the surface selected but I do not seem to be able to find the spot where you map to the .jpg and does that .jpg have to be in the Librart before starting this process.
Including a view of my entire desktop
Eduardo Rolon
Open Options-> Element Attributes->Surfaces
and select New
On Color or Luminance Select Image as the type
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Click on the "Sub Setting" icon
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Click on the ellipsis icon
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Click on "Load Other Picture"
Select "From File Dialogue"
then go look for the JPG were you saved it or have it stored.
Repeat for the other channel
AC29 US/INT -> AC08
another Moderator
