2014-07-31 05:58 AM - last edited on 2023-05-11 12:50 PM by Noemi Balogh
2014-08-06 05:56 PM
2014-08-07 04:33 AM
adamsb wrote:I am not sure that BIM Components link works.
Have you tried using bimcomponents.com? It even has a weblink at the bottom of the object dialog box.
2021-09-17 08:13 AM - edited 2021-09-17 08:15 AM
Archicad also has a premium surface library which you can add. Very product specific textures I usually download from the producers website.
And you can also use quixel as it is incorporated into TW/EPIC/GS.
2021-09-17 08:29 AM
There is a standard surface library included with your Archicad installation.
This allows you to add many new surfaces that may not be included in the default template.
You can load this library (if it isn't loaded by default), and when you create a 'new surface from catalogue', you can brose it to find the surfaces you want to create.
If you have a Select Service Agreement (SSA - yearly subscription), then you have access to an extra surface library.
When you go to create a 'new surface from catalogue', there will be an option to download this additional library if it is available to you - at the bottom of the dialogue window.
There is also a BIM Components link there as well that has some surfaces in it..
2021-09-17 09:05 AM
A building material is mostly a 'container' for defining the cut fill, surface and priority for connection. If you have a half way decent template, most types of actual building materials (bricks, concrete, wood, metal etc etc) should be there. Just duplicate the closest match and change the fill and surface etc as needed.
Since the building material is a collection of other attributes like fills and surfaces, but also defines pens, there is very little use for sharing these around, since they will only work within the same template or you will 'pollute' your file with new attributes that are likely duplicates of something that is already there.
2021-09-17 10:09 AM
For masonry we mostly use textures which are provided by the company that produces the bricks.
If you are just looking for textures to incorporate in your surfaces you can have a look here:
2021-09-18 01:40 AM
Easy answer. go to https://www.sketchuptextureclub.com/textures/architecture
Create a free account and download great tileable textures.
