David Bearss
Lines in transparent materials
I am experimenting with a rendering techinique and want to include transparent and translucent materials. I have created some different transparent materials with different transparency and color and then I have created some tree forms from slab tool and applied a transparent material to get desired effect. Sometimes the trees show grid lines acros them. When I apply the material to a large slab or wall there are no lines. Am wondering if the complexitiy of the tree form is causing?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
41 Replies 41
Dwight
What if you make a complex profile wall with the shape instead of a slab? Any difference?
Just like all things can be made a complex profile, all words come from Greek.
"Kimono," for instance.
Dwight Atkinson
David Bearss
Have not tried that. And to be sheepishly honest I have not even tried using the complex profile. I will have to experiment with that this evening.
David Bearss
Alienware 17 R5
David Bearss
Well the profile tool is cool and easy. However the lines stil appear. Might note that as i rotate the view around the line seem to be related to screen position and view angle rather than directly associated to the object.
David Bearss
Alienware 17 R5
David Bearss
Same tree different angle view
David Bearss
Alienware 17 R5
Erika Epstein
why don't you post a file with one of the elements that show the grid
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Right. Select one tree and 'save selection as module' - it'll give us the tree and the material to study.
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Erika Epstein
Tree slices, what a fun idea!
The tree I created I stretched to make 25' wide. I rotated 3 more around its central axis.
I then shrunk the tree slice to 3' high, 2' wide, keeping its thickness at 1/8".
No lines.
The lines on yours look like they might be a cover fill as others have suggested. Look close, its not a grid, but perhaps a roof shingle ?
Great idea
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
David Bearss
I will post these two trees. These are more complex versions that seem to have more lines running through them. Also the darker one has lighter splotches in them as an added bounus. Weird.
David Bearss
Alienware 17 R5
David Bearss
Um, sorry to have to ask, but, where would I post the module?
David Bearss
Alienware 17 R5
Dwight
Consider putting a texture on the material - like an image of noise.
Dwight Atkinson
