Learn more
Material intersection problem???
Two walls has perfect intersection in flor pan and in section, but in 3D their materials don't intersect the way i like. One is glassed and other one is concrete. Edge material of concrete wall becomes glassed, but it should stay concrete. What should I do?
4 Replies 4
Dwight
Create a tiny gap at the intersection.
Dwight Atkinson
But those two walls are both slanted. if I create gap they will not matched
Dwight
Fine. As if you pointed that out before, eh?
Make a short return for the concrete wall.
Also: This isn't magic.
Archicad tries to be a realistic modeller.
How would a tilted wall of glass meet a tilted wall of concrete?
Does the concrete return?
Does the glass overshoot?
If you think through the architectural issue, then you can model it.
Dwight Atkinson
Works for me....
Are those 2 walls on the same layer? Because if they are not, then your output might be a result of both layers with different Layer Intersection Group numbers...
