Before importing the jpegs into PM open them in Photshop to verify the dpi resolution. I have seen that even though you specify the resolution in Art it sometimes defaults to 72dpi. Also if you open them in Photoshop then you can see the size in inches of the image at a specific dpi setting, with that info you can then adjust the jpeg in PM.
BTW I am not fond of using jpegs for my images I normally use tiff without compression, it saves time and quality by not having either PM or ART having to compress and decompress the file.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
