Redshift Rendering settings - example ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-11-14
03:45 PM
‎2023-11-15
11:50 AM
Hi there,
I'm looking for rendering setting (photorealistic rendering) with Renderer: Redhift.
a) for Daily outside
b) for Daily inside
c) Night outside
d) Night inside
All with lamp and light
ArchiCAD Tutorials only shows the menu and buttons, but no example setting........
Workstation office specs: mac OS, Apple M2 Max, 64 GB RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-02 05:24 PM
Hi Andreas! Make an archice, pla-file, of your project. Zip it and post it here. That will make it easier to spot what's wrong.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-02 06:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 08:59 AM
You did not include your Archicad file in the folder so it's hard to search for errors. But maybe you should check the following:
- Choose an HDRI on your computer if it's missing.
- Under "Light Adjustments", make sure the additional lightsouces you would like to use are checked. If you want to see the light from the HDRI only you can uncheck all three.
- Go through your materials to see if they are properly set up. When you are testing the light you could begin with a simple material with just a plain colour in the "color"-channel. "None" for texture and "Normal" for mixing mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 10:06 AM
Hi Karl, do you have an example from yourself with screenshots etc, how to do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 10:11 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 11:36 AM
Its easier if you save as an archive file with .pla as file ending.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 11:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06
04:54 PM
‎2024-05-09
12:00 AM
If I open your file and , for example, choose, the HDRI " Bäume 01 GS.hdr" in the german library I get the following result. The first interior is with only HDRI, the second is with lights switched on. You can try different HDRI:s, add or remove lamps and change the materials to experiment how this affects the render.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2024-05-06 05:12 PM
Ok, i will try, thx.
PS:
the file is a test object 😉
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
