Rendering on a remote computer/farming
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-01-17
09:15 PM
2023-05-11
12:23 PM
Noemi Balogh
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-18 01:00 AM
You need Cinema 4D or another professional tool to do this and ONLY for multiple frames. Single frame rendering remains limited to one machine at a time.
"Render King" is a site you should investigate since they support distributed processing for many rendering systems.
But the phrase "render farm" is silly, considering that it conjures bucolic scenes of happy animals lowing calmly and chewing cud and not row upon row of humming, faceless automatons like in a larger architect's office.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-18 10:18 AM
I think you can do single frame rendering using multiple machines. VRay will do that and so will Maxwell.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-18 06:42 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-20 06:32 AM
https://www.indigofigs.com
https://www.facebook.com/indigofigs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-21 02:55 PM
You mentioned Cinema 4D for multiple frame rendering..
How difficult is the process to merge/import the archiCAD file into Cinema 4D - does it take all the textures or do you have to reapply to each surface or element..? Also, does that mean ArchiCAD is 'freed up' when rendering in Cinema 4D? So you are able to work on a different project in ArchiCAD whilst CD4 Spits out the Animation?
What about importing camera paths and settings and lighting - or are they all applied in CD4?
Chrissy
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-21 04:56 PM
- The material names transfer when you export the file - you will have made your Cinema materials ahead of time in Cinema since they are more sophisticated than in Archicad.
- Archicad is freed up but your computer is not. You want to let all of your computing power address the rendering. You can also send your file to a place like "Render King" http://www.renderking.com/
- Never apply cameras or lights in Archicad when you plan to export the file since they are clunky compared to what you can do elsewhere. Lights are located but values are wrong. This isn't so bad if you use my cinematic lighting techniques.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-21 05:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-21 11:46 PM
I have Cinema 4D - but just haven't had to time to look into it yet.. it just sits there.. I love Light Works.. but want to take my work to the next level, and really want to look into exporting to another program for the animations for a combination of reasons..
In your opinion; Does a animation program like CD4 handle the process of rendering an animation 'better' when used in conjunction with archiCAD?
Is it less fragile with the multitude of objects and lighting etc? - I guess what I am trying to ask is if more powerful? If you had it you would would not hesitate to use it over archiCAD for the rendering process of an animation?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-01-22 12:11 AM
Artlantis currently cannot distribute processing among several computers.
Considering Cinema 4D, or any professional-level rendering/modeling application leads you to a new profession. Mastering cinematic modeling/surfacing/lighting takes all day. All week, perhaps. Maybe an entire month. Or longer. A year, even. Professional rendering applications offer:
- faster rendering
- distributed processing of single frames and animations
- materials with sophisticated light reflection behavior [Cinema 4D has several hundred adjustments you might make to any surface]
- sophisticated camera controls, animation timeline
- fast previewing of effects
You simply don't export your Archicad file to something like Cinema and get a usable product - the environment behaves differently - more like a
studio, but once you have created an environment with compatible materials and lighting, it is routine to bring in an Archicad model.
It goes without saying that modeling is quicker in Archicad.....
