JamesBell
Shadows not displaying in section
I am trying to display shadows in section, but cannot see them.
When I however over the wall I can see that the shadow is being cast, pictured belowScreenshot 2023-10-04 211628.pngScreenshot 2023-10-04 211702.png
1 Solution
DGSketcher
Legend
Try changing your Uncut Fill setting from "Nothing" .
Go to post
9 Replies 9
runxel
Pretty sure there is a Graphic Override currently at work, no?!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
JamesBell
Hi!
No there is no graphic override on now!
Laurentiu
I would need a screenshot of the entire Section Settings - Model Appearance tab to say for sure, but I think it's because of the Fade Distant Elements. If an element is faded (outside of the faded edge that you control in floorplan), it does not receive shadows.
Edit: It's not that, you do have the checkmark for faded elements to have a shadow.
Laurentiu Cauni | Architect | AC 17-28 INT
Windows for AC & iOS for BIMx
JamesBell
Here are all my settings for model appearance, I have also tried restarting my computer a few times.
Have you used zones in your rooms?
I am wondering if they are hiding what is behind them.
JamesBell
Hi Barry,
No zones used, I've only used basic elements, walls, slabs, windows, doors etc.
Xandros
With your mouse please hover over the wall like you did in this screenshot here, but this time also caputre the info panel that is cut off. Sometimes there might be valuable information written in there.
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
DGSketcher
Legend
JamesBell
That worked!! thank you so much.
