Visualization
Shadows on a 2d plan?
Is it possible to make shadows on a 2D plan.
Like illustrated on the attached file.
Not in 3D render but in 2D
20 REPLIES 20
Ok. I will try to study the 3d documents, to find more information about the subject.
Thanks for your help.
If you want to look directly from the top in the 3d document. Like your file. Which settings do you use then.?
Eduardo Rolon
Menu -> View -> 3D View Mode -> 3D Projections Settings
Select Parallel Projection and then Top view, move the camera to define which side is up and move the sun to select the direction of the shadows.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thanks for the help.
It was very easy to use the 3d document. I think this would be easier than faking with fills.
Is it possible to turn off shadows from wall's??
Eduardo Rolon
Yes.
Now you need to read up on;
View Sets
Layer Sets
Conceptually you would create to views of the 3D Document. In the one with shadows the layer for the walls will be off. In the one without shadows you will only have the walls. Both of theses views will be placed on a layout on on top of the other.
AC29 US/INT -> AC08
another Moderator
You can also generate a 3D top view with just the elements on that you want to cast shadows.
Then place a 2D marquee around it and copy just the shadows.
these can then be pasted into the floor plan in what ever layer you want so you can turn them on or off.
Just remember that these shadows will not change as you alter your design unlike a 3D document which is live.
Thanks, I will try it out.
ngoldie
I was wondering where the 3D copy option was, I can't seem to find it anywhere?
Thanks,
Naomi
Archicad 20
MacBook Pro - laptop
You need to be in the 3D window and have it set to the 'Vectorial Engine'.
Doesn't work in OpenGL.
Then place a 2D marquee.
Then CTRL+C and the dialogue will appear.
