Visualization
Show some of your Renderings
I thought it would be a fun idea to show some renderings of homes you've designed in Archicad, kind of like a little portfolio or show and tell.
So I'll start with a few:
361 REPLIES 361
Hi all!
Please tell me some advice, how can i make this photo more realistic? I rendered this with AC 13 Lightworks engine, I didn't use photoshop or something like that just ligthworks. Every advice would be useful!
Thanks in forward!
Alex
This is a beach house I designed in ArchiCAD 12 EDU and rendered in Artlantis and touched up in photoshop cs4. More info is on my blog: http://ethanjones.wordpress.com
Sightline
ArchiCAD 12 and Vray
Diego Torres
Architect-CG Artist
Architectural Concepts and Visualizations
ArchiCAD 4.55 - 24
http://www.sightline3d.com
Quick one modeled with ArchiCAD 13, rendered in 3D Studio Max & Vray.
Still learning, but slowly getting there!!!
Mike
Mats_Knutsson
Mentor
I see several Vray renders in this post. What is your experience with ArchiCAD+VRay in general? Cumbersome, normal or delight?
Is it a valid everyday rendering workflow considering model revision etc when using Vray on 3D Studio? I have a few questions about this. Many companies seem reluctant to use C4D+Vray when they have in-house expertise with 3DS.
/Mats
AC 25 SWE Full
/Mats
archicad material manipulation i TERRIBLE and i think that archicad have worst material edit possibilites (very very slow changing and editing materials) So i use archicad only as a modeler (but as time pass i use it less and less cos archicad dont have modeling tools and most of time i can draw cubes only)
Vray is the Best rendering program out there
Super fast - Super results
Sketchup + vray (only good with small models if u have complex scene then sketchup will not be able to navigate trough model. Sketchup will start to work like video on 5 FPS
Rhino + vray (Perfect for me) no limitations
Best - 3ds + Vray + RTVray
This is the best combo !
You can have real time render with 3ds
C4d - tryed - erased - didnt like it
archicad to vray dont have any workflow !
if u need to update something you will lose 30 minutes and that sux
NeckoFromSarajevo wrote:
archicad material manipulation i TERRIBLE and i think that archicad have worst material edit possibilites.
Ths is exactly my opinion too!
archicad to vray dont have any workflow! if u need to update something you will lose 30 minutes and that sux
Alas, this is also true! 30 to 90 minutes!
Mats_Knutsson
Mentor
I agree with the material handling. I don't know exactly when the rendering stuff will be upgraded/changed but I'm sure it's not far away.
Regarding Vray. Are there any advantages using C4D+Vray instead of 3DMax+Vray?
/Mats
AC 25 SWE Full
Eduardo Rolon
The Advantage is that you can get the plugin for C4D which lets you update the model without having to redefine the materials. This is a very good workflow, akin to the Update with Reference option in Artlantis.Please see
http://dinnye.neobase.hu/
AFAIK there is no equivalent for 3DS+Vray
Plus C4D runs in OS X
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
TMA_80
Hi !
In the Agsvis (who developped vray for sketchup & Rhino )website , ArchiCAD was leading the vote for the product for which we like to have a VRAY plugin integrated to...however
http://forum.asgvis.com/index.php?topic=6439.msg36263#msg36263
i don't know how eficiente it is ( and I don't think it could reach the c4d importer ) but there seem to be an equivalent for 3dmax
http://www.scriptspot.com/3ds-max/scripts/archicad-importer
AC12_27 |Win11_64bit|
