Visualization
Transparency in sketch render
Erich
I am having an issue where a model initially sketch rendered glass with transparency off - but now will only render with transparency on.
Is there a setting, other than the transparency toggle in the 3D window Settings, that controls transparency in a sketch render?
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
14 REPLIES 14
Here is the answer:
http://helpcenter.graphisoft.com/troubleshooting/3d-modeling/texture-overwrite-fails/#Transparency_n...
adamsb
laszlonagy wrote:
Here is the answer:
That's great news!
In the meantime, what I've found to work okay is to change the OpenGL transparency settings to 0 just during the sketch render. Works pretty well, even though it is an extra step.
AC21 64-bit
Mac OSX 10.12, 4.2 GHz Intel Core i7, 64 GB mem
Mac OSX 10.11, 3.4 GHz Intel Core i7, 32 GB mem
Erich
Personally I am looking forward to AC19. The fix listed in the help center
Transparent surfaces are not rendered as such by the Sketch rendering engine
is actually exactly the reverse of what I have experience. I cannot get transparent surfaced to render opaque. It sounds like in AC19 we will have a toggle in the render engine rather than other settings to control transparency. This can then easily be saved with the view settings.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
Yes, it seems there will probably be a new "Transparency" checkbox for the Sketch Render in ARCHICAD 19 (of course nothing is final until it is actually release).
Erwin Edel
That toggle would be a very welcome addition for our artist impressions.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
