Vectorial hatching positioning
Is it possible to adjust the origin level of a vectorial hatch?
I have created a basic custom fill (horizontal lines, 1200mm apart) and it is assigned to my external wall material. My building has a 900mm high concrete plinth starting from +0.000 but my hatch also starts at +0.000 which means that after the plinth I am left with a 300mm gap and then my 1200mm gaps continue after this.
If I could raise the starting height of my hatch by 900mm this would solve my problem!
Any help would be gratefully received!
James
1 Reply 1
Eduardo Rolon
In the 3D window use the Align texture option under the Design Menu. There is a recent post with this answer.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
