View to Layout - Display question
A 3D view is created and dragged into the selected Layout,
however The Layout image shows the "grayed" bounding box
background of the view.  See attachment below.
Is there a way to display the View without the gray bounding
for consistency with other images in the Layout?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 Replies 3
Lingwisyer
Guru
That would just be your background colour below the horizon? Have you tried setting the View to use a 3D Style that is white below the horizon?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
ryejuan
In the layout view select the drawing element then go to your info box and check "transparent background" image below for your reference, hope it helps.
WINDOWS 11 PRO
Thanks for all the replies,
I try to answers them  before and my message was blocked.
Anyway, the solution is to use the View Settings for 3D and select the settings for "Simple Shading w/ Shadows" and "Outdoors Daylight Basic"
When dragging the view to the Layout, the shaded bounding box is not visible.
