2022-06-03 05:41 AM - last edited on 2023-05-11 03:02 PM by Noemi Balogh
A 3D view is created and dragged into the selected Layout,
however The Layout image shows the "grayed" bounding box
background of the view. See attachment below.
Is there a way to display the View without the gray bounding
for consistency with other images in the Layout?
2022-06-03 06:57 AM - edited 2022-06-03 07:01 AM
That would just be your background colour below the horizon? Have you tried setting the View to use a 3D Style that is white below the horizon?
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2022-06-03 08:15 AM
In the layout view select the drawing element then go to your info box and check "transparent background" image below for your reference, hope it helps.
2022-06-06 08:01 PM
Thanks for all the replies,
I try to answers them before and my message was blocked.
Anyway, the solution is to use the View Settings for 3D and select the settings for "Simple Shading w/ Shadows" and "Outdoors Daylight Basic"
When dragging the view to the Layout, the shaded bounding box is not visible.
