‎2016-04-15
01:34 PM
‎2023-05-11
11:58 AM
Noemi Balogh
‎2016-08-05 07:52 PM
Steve wrote:I can see it fine. It is rather big and pushes forum boundaries off screen on most screens, but it is visible.
Can anyone else see the image in that post?
‎2016-08-08 09:21 AM
‎2016-08-08 10:36 AM
Steve wrote:I see the pic, larger than the standard width of the forum page ...
‎2016-08-08 04:57 PM
‎2016-08-08 05:21 PM
‎2016-08-08 09:34 PM
Erwin wrote:Thanks Erwin, I think a GO is going to be a good solution to set up. All the solutions for what I want to do are more difficult than it should be using ArchiCAD/CineRender.
Steve,
I do not have ArchiCAD20 yet, but that image is very possible to do with the overriding all but the glass surfaces with a white surface.
I would put a general light inside with infinite strength, no shadow casting, and put lights at about 50% in the cinerender settings, this helps a bit with making the interior less dark, which in turn makes the glazing look a bit better.
A few replies futher up on this topic I wrote how you would be able to achieve it relatively quick with ArchiCAD 18/19 by hotlinking the PLN to a seperate file.
Given the approach of overrides, you might even play a bit with shades of grey for different surfaces (like a roof, or windowframes) to give the model a tiny bit more richness and definition.
