Visualization
archicad 3d Roofing tiles problem. Pls help
please am a novice help me, am working on a 3d drawing.
Its just a square bungalow and i roofed it with roof tiles in the material option. But the particular tiles texture i used in the 3d, has a default color of red. And i want same tile texture but blue colour. Pls how can i change the color to blue and have same texture of the red tiles. Without selecting plain blue that has no texture or corrugation on it. Even if its a software i can use an achive it, pls help me and post the tutorial. Am useing archicad14, pls if your useing screenshot to explain it well to me, pls use archicad14 screenshots. Please i beg. thanks
1 REPLY 1
vistasp
You will need to add a new material.
Have a look at this thread.
http://archicad-talk.graphisoft.com/viewtopic.php?p=202208
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
