Visualization
cineRender by Maxon add-on unexpectedly closed.
mi_jan
Everytime I Render a view it starts calculating the cgi and then it gets stuck at preparing 5.6%, eventually it says its finished but its not. When I open up render settings again I get the following error message
"Warning, cine render by maxon add on has unexpectedly close Archicad should be restarted. "
p.d. It happens with the custom rendering scene I have been using for the past year and also archicads default render scenes
I can't render at all, the preview comes out in the render settings window but the actual image does not. I tried Marquee with several areas of the project but still no luck.
iMac - MacOs Big Sur 11.6.6
Archicad 24 - Latest Build
Archicad 25 - Latest Build
14 REPLIES 14
derekjackson
Thanks, but the marquee trick doesn't work. I even have issues with blank files, so it seems to be independent of the model content.
Erwin Edel
Tried a reboot I assume?
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
derekjackson
Many times!
Pato99
Just chiming in here.
I've had this issue on AC20 for a while now. I don't think it's a ram issue, I've got plenty and it happened one day out of the blue, then started a few month later on my laptop.
I've been getting around it by hitting render (getting failed render) then as quickly as possible re-rendering. It seems cinerender takes too long to start but once it's running you can jump on the back of that last startup.
Personally I think due to a win 10 update, hence the delay of the issue between devices. Re-install of software should fix the issue, but this workaround works for me at the moment.
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
Hi everyone,
I know this is an odd solution - I can't explain why it worked, but for me it did and maybe it'll help someone else out too.
I kept getting the same "cineRender by Maxon add-on unexpectedly closed" error message, and tried EVERY suggested solution I could find (including totally uninstalling and Archicad and re-installing) and nothing worked.
But then I had a weird idea and....
....I turned my VPN off.
Voila! It started working working immediately and has worked ever since!
Hope this helps save someone else from going through what I went through today!
Cheers!!
