2 weeks ago - last edited 2 weeks ago by Eduardo Rolon
Hello everyone!
I am using Archicad 29 and for no reason my cineware has stoped working, well it does work but it used to take 5 sec to render an image and now it takes ages and basically i have to quit the process each time... for no reason at all!
I am using Asus Rog Zephyrus G15, with RTX 3070 and it used to go extremely fast before this . I have checked my GPU and RAM and everything work fine from Hardware-based option!!
thank you in advance!!
2 weeks ago
Try using a different render scheme.
I don't have Archicad with me at the moment so I can't remember their names, but try a 'fast' one instead of a 'final' one.
2 weeks ago
i will give it a try
a week ago
So just an update , it looks like the project is "heavy" or somehow to much "complicated" , which is not!
i gave it a try to render in a new simple project and it worked. but in mine didn't .
is it a way to chech and "clear" my curent project?
a week ago
There will probably be a too much complex object or some textures which causes this.
Try to turning off layers in bulks so you can find layer in which the problematic object/texture is.
Also, to easily say if it is object or texture, try set Graphic overrides so the whole model is with one texture (colour).
