Visualization
colored floor plan
How to generate\create colored floor plan for presentation from normal archicad plans?
I have attached a sample image of my requirement.
10 REPLIES 10
You can use Image Fills.
Search in the Help File for "Image Fills".
You may refer to any of these links for suggestions on how to achieve your colored floor plan:
1. Do it in Photoshop
2. Karl's Piranesi/Axo suggestion
3. Various Techniques
Rakela Raul
great !!
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
The easiest approach is to use simple cover fills.
Martha Calderon's illustration work.
In a "Design Graphics" July 2001, article she talks
about her process. At that time it was strictly a
2D linedrawing import with lots of Photoshop.
I think you can easily see how to get her look in far less
time with AC today + minor Photoshop.
Snap
Just asking...
Is possible to assign a slab a fill and see the image fill in some plans and a vector fill in other ones?
Or see the vector fill in plans and image fill in 3D views? In a top plan?
Sometimes is useful to have some plans in line and other ones filled with patterns...
Thank you!!
David Maudlin
This can be done by using a Cover Fill for the 2D (Plan) view, and textures with the OpenGL Engine (or PhotoRendering) in the 3D Window, including Parallel Projection Setting > Top View for a Plan view in the 3D Window.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
check out https://www.pixelsquid.com/ which is mostly for use with Photoshop.
Just a simple screen shot of these can be used in ArchiCAD.
quick and easy at - with a white floor that is.
