Landry is right. Material creation must be manually matched between the different rendering methods because LightWorks in an Add-On with different material potentials.
You should review the LightWorks Archive information for shader-based materials that can be saved in archicad.
There's a nice sandstone in there, for instance.
Dwight Atkinson
