‎2007-11-14
01:04 PM
‎2023-05-11
02:34 PM
Noemi Balogh
‎2007-11-15 12:45 PM
‎2007-11-15 06:58 PM
‎2007-11-15 10:09 PM
aggie463 wrote:Artlantis Studio will do it like you describe it.
Is there a way, in AC11 or any other program, to take a model (made in AC11) and create a rendered movie of a section plane moving through the building?
In effect, much like moving a section plane through a model in SketchUp, but with the graphical output rendered rather than like SketchUp...
‎2007-11-15 10:18 PM
Thomas wrote:Is there somewhere I can read up on how? If its Artlantis im sure its fairly simple. Thanks!
‎2007-11-16 08:01 AM
Link wrote:Definitely. The Ray Harryhausen achievement award.
I wonder if that wins the longest workaround award?
‎2007-11-16 08:23 AM
aggie463 wrote:THe problem with Artlantis is the lack of documents. What you do is turn on and set the position (in a 2D view) of the relevant Clipping Plane at the beginning and the end of the animation (as well as other transitions you may want). Artlantis Studio makes all the in-betweens for you.Thomas wrote:Is there somewhere I can read up on how? If its Artlantis im sure its fairly simple. Thanks!
‎2007-11-18 09:37 AM
‎2007-11-18 06:38 PM
aggie463 wrote:I distinctly remember doing exactly this in GDL in Archicad 6.o or 6.5 ... but for the life of me, I don't remember HOW ...
Whew...this is all overwhelming to me....Im not that advanced a user yet. I hate to be a bother but could I perhaps get a more mid-level explaination?
I think I somewhat get the main concept: each frame would have the section plane move just a fraction more, correct? I know I can manage this, but once you get into the cameras, key frames, etc stuff then I get a bit comfused as Im just in the past day or two beginning to explore this feature.
Thanks for all the input!
‎2007-11-18 07:47 PM
‎2007-11-19 12:45 PM
Djordje wrote:Yes, it needs to be done with the CUTPLANE command the way Djordje described.
AAAARGH! I am getting old ... can someone check whether there is a CUTPLANE GDL command?
