alemanda
night scene with ies lights
Did anybody face the challenge to render a complex night scene (around 1 mln of poligons) with (many) ies lights (let's say around 30 ies lights)?
What are the settings to prevent very bad artifacts in lighting?
Is the render time still reasonable (reasonable = 4 to 6 hours for a 2000x1500 picture)?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
3 Replies 3
alemanda
this is a very small part of the scene ... just 5 ies lights and I cannot get a decent result in lighting.
How to achieve a decent result?
I tried changing the Irradiance Cache parameters and I put the interpolation method in least squares, density high... but nothing.
Method is IR. QMC seems to take too long time and the result, even if is the most accurate, is too grainy.
Any help is highly appreciated.
AC27 latest hotfix
Win 11 Pro 64bit
Erwin Edel
Maybe the test scenes used in the youtube tutorials are helpful for settings.
http://www.graphisoft.com/archicad/archicad-18/rendering/#sample-project
You can export the cinerender settings as scenes and import them to your project to try out.
Not sure about IES lights yet. I haven't done any serious interior rendering yet at that level.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
alemanda
Thanks.
Due to a tight deadline I cannot conduct more tests because I have to deliver some pictures ... so at the moment I give up.
But I will be back.
Having a good (?) renderer inside archicad speeds up the workflow. So I'll be back with more tests.
AC27 latest hotfix
Win 11 Pro 64bit
