ā2005-04-13
08:33 PM
ā2023-05-11
02:37 PM
Noemi Balogh
ā2005-04-13 10:23 PM
ā2005-04-14 04:22 PM
ā2005-04-14 05:54 PM
Shae wrote:Are you certain you need jpg images? A lot of publishing software will happily work directly with eps/ps/pdf files.
i am trying to publish some floor plans for a brochure. i tried to publish as pdf at 1200 dpi, but when i open it in photoshop, the lines are gray and flat, and some are missing.
ā2005-04-14 06:43 PM
ā2005-04-19 10:25 PM
ā2005-04-19 11:13 PM
ā2005-04-20 12:51 PM
Shae wrote:Perhaps your line weights are too fine? A hairline thickness at 1200 dpi would be very fine, and would be commonly rendered as light grey (or could even disappear. Try modifying the weights in your pen settings and see if you can improve the output.
wes,
thanks for the input though.
ā2005-04-22 09:01 AM
Shae wrote:PDF.
no i don't need jpegs in particular, but i do need some common format that many programs will open. also, i'm looking for a process without so many steps.
do you know of any vectorized drawings outputs read by any media browser or program that i can eventually use in photoshop?
ā2005-04-22 12:17 PM
