Wishes
Door opening lines cut in section
I wish: the opening lines that appear in the elevation of a door did not appear when that door is cut in section. The dashed or dotted line is a 3-d element. Depending on the thickness of the door, it shows in section. In the case of a 3/4" door (D1 23) that I use for cabinetry it appears 23/64" in front and behind (to the left and right) of the door (shown red to clarify). In 1/2":1' scale this is a problem.
0 REPLIES 0
