The roof accessories add-on will allow you to automate objects added to the edges and surface of the roof planes.
As Richard suggested Cadimage provide a good add-on.
I am sure there are others out there as well.
Rather than relying on a third party add-on I have created my own objects that I can place and manipulate.
Or complex profile beams and walls and possibly even the profiler add-on (free) for horizontal fascias and gutters.
While not connected to the roof (they won't adjust automatically when you adjust the roof) they are relatively easy to manipulate.
One of my upcoming tasks it to sit down and make objects that will use the roof accessory add-on.
The add-on id free it is just the objects that work with it that you may have to pay for (unless you are good at GDL programming and can make your own).
Just for the record I haven't voted yet because if I did I think it would be on the not so important side of things as it really isn't important to me and I didn't want to affect the results.
I can't see how it would be possible to change the flat edge of a roof into a profiles fascia, gutter, barge etc., with different materials without using and add-on to attach an object that will adjust as you change the roof. The object then gives you the control of the profile and materials.
We could possibly have more options to curve or chamfer the edges rather than just adjust the angle but I think anything beyond a simple profile would be next to impossible.
