This wish relates to any complex profile, whether it's used in beams, walls or columns, as well as the simple 'block' beam & column
Currently when a complex profile is applied to a beam, column or wall, it is "extruded" along the path of the beam/column/wall, but the end cut planes are always set at a vertical (for beams & walls) or horizontal (for columns)
This is fine if you only draw columns or beams that do not
incline.
Each tool/object should have the ability to allow the user to control the angle of the end cut planes relative to the path.
Options could be:
- Angle (input)
Bisect adjacent
Perpendicular
Vertical/Horizontal
This would allow beams & columns with complex profiles (eg. steel) to intersect correctly (see images)
ArchiCAD 24 (build 5004)
MacBook Pro (16-inch, 2021) Apple M1 Pro 32GB RAM | MacOS 12.0.1
Melbourne, Australia
